PZaff
- December 1, 2018
- AZ
- 2006 explorer xlt 4.0 4x4
Hi guys, I am new here and this is my first post. My o2 sensor was not working correctly so I bought two new ones from rockauto. Put them in and still the same issue. P0135. Comes to find out that the wires on the pcm side of the connector are broken therefore throwing a code. I found this out while checking with multimeter the connector with the ignition on. When the wires moved there were sparks against the transmission housing.
I am glad that I know what the problem is however I cannot access the wire to fix the connections. I was trying to route the wiring back across the transmission to the driver side so I can pull it lower to repair it but it keeps getting snagged on things. I have limited room getting my arms into the correct area. Does anyone know of how to fix this. I can’t find another thread about this.
This is our only vehicle so the sooner the better. Thanks.
