obd 1 codes | Ford Explorer Forums
obd 1 codes
nugs
fargo, nd
92 xlt
just did codes on my 92 x koeo stc 111, cm 157 and 536. koeo 111. Any advice would be appreciated!
Just did a scan on my 92x -- 11 or 111s is pass (good) - 536 code because you may not have floored the gas pedal during a particular part of the koeo test (i forgot to do that too) - 157 (maf sensor) - the codes are in the haynes manual chap 6
ya my bad the maf is low voltage is that a problem with maf or power wire going to it?
correction nugs: 536 is Brake ON/OFF (BOO) circuit failure/not activateed during the KOER test
and i just caught a typo in the first and should b KOEO stc 111, cm 157 & 536, KOER 111, any help appreciated!
i thought about it and i had started the truck with the maf harness disconnected once (157), and my brake\hazard fuse had blown on me (536). I cleared the codes by pulling the wire during the test, drove the truck and reran test, all 11s and 111s. thanks for the help docksider!
