Huntsman06
- February 7, 2017
- UT
- 2004, Explorer XLT
So, I bought a magnet mount for my phone that is clipped to the air vent just to the left of the steering column in my 2004. Unfortunately, there isn't any kind of power source I can plug my phone into while it is mounted and, after a long day, my phone is usually desperate for some power and a long cord from the center console cigarette lighter is out of the question. In search of a solution I have come across a number of these:
The OBD port provides plenty of power and it seems to be the best option to avoid splicing into any wires. However, I've heard cases of "misusing" the OBD port can cause all sorts of issues from draining the battery to actually damaging the computer in the car. I believe the OBD port supplies a max of 30v of power and any USB adapter I've found steps it down to 5v for USB (which I would expect), so I don't see the power draw overloading the OBD while charging my phone while driving. Furthermore, I would expect it to only drain power from the port if the USB cable is actually plugged into something.
Unless I am missing something, I can see no reason why the OBD port would be a bad method charging my phone. Thoughts?
