Odd Idle? | Ford Explorer Forums
Odd Idle?
EB Bauer
Albuquerque, New Mexico
1991 Eddie Bauer
In the morning or late at night I have this weird thing going on with my idle. I will start my Explorer and the idle wil go from 1500 rpm to 3500 rpm up and down until I hit the gas pedal then it returns down to about 1000 rpm. It will then run rough for a few seconds till it gets back on its feet and then run fine. I have noticed that if it is cold out it will do this but not all the time. have any of you had this same problem? also what should my normally be at? I have a 91 EB with the V6 4.0. Everything in the engine is stock for now anyway. Can any of you help me out with this? I don't want to start putting parts in it hopeing it will fix the prob, that can get expensive. I just replaced the O2 sensors, thermostat, and the fuel presure sensor. I need help real bad! Thanks for all the help in advance!
Scott Bauer
'91 Eddie Bauer
