faron021
- December 2, 2011
- Florida
- 2001 Explorer Sport
here goes, this is my girls cars 01 4.0 sohc 2door, this is the older motor like the 99-00 had. she brought it with 102XXX miles. didnt think it was in to bad of shape for the price so she got it. had to replace a few parts, first thing i did was a tune up, org fuel filter (black) rusted plugs also org, org wires, and coil. well i changed everything i started just with the plugs i put e3's in it, while i was changing it the boot end of one wires broke i believe it was #2 was so old it shrink to the plug so i went ahead and replace the wires. few weeks ago she was saying it was shaking real bad, with the luck i was having with e3's at the time, i changed them to ngk while i was doing that i said i would go ahead and change the coil, so i put a accel coil #140035.
i was told if you unplug the IAC at idle it should almost or complately kill the engine so i did this and it didnt even seem like it did anything, so later on a put a new IAC on it, as well as cleaned the Throttle body and some of the intake, still shakes, no change with unpluging the IAC, but something new has devoloped over doing this. now if i rev it at idle to any rpm in stead of returning to the 500-600, it hangs at 1000rpm for a little to goes on down.
my only guess is theres a vac leak somewhere. my best guess would be the intake gaskets, every ford i have owned at around 100k they seem to go out.
any help or advice on this thanks.
