diesel_s
- October 7, 2008
- Buford, Ga
- 2008 ST Limited
My truck has been sitting in a body shop for about a month, i was T-Boned on september 14th...truck was transported to a body shop shortly there after at the expense of the other persons insurance company. Now, problems with the vehicle have begun to occur since i got it back, steering was extremely loose and there was a grinding noise so I changed the wheel bearings and that was fixed. Theres a clicking noise that sounds like metal falling on top of metal when I got over bumps now....a vacuum leak has somehow appeared somewhere and worse of all, I just fixed my transmission back in August, I had a bad output speed sensor...now i'm getting the code P0735....and the truck won't go into 4th or 5th unless I press the Overdrive button to cut it off and then press it again to turn it back on......suggestions?!?!
