4x4xlt99
- May 19, 2011
- Huntington, WV
- 99 XLT
Tranny takes a few seconds to go into gear...
Ok I just bought a 99 Explorer XLT 4x4 loaded with the Sohc 4.0. I kind want to get in the 4x4 scene that's why I bought it but there is an issue with it...when you put it in gear for overdrive it feels like it kicks in but it don't, not for 5-10 seconds. For those 5-10 seconds it kinda pulls buy feels like its barely catching. Then after those few seconds it kicks in and pulls great and shifts out awesome. I can prevent this by putting it down in first gear then manually shift it to overdrive once it takes off. You only have to do this when you take it out of overdrive, for example, your put it in reverse or neutral or any other gear then you have to manually shift it. But if you leave it in that gear then its fine, you can stop and go and do whatever and it shifts fine but the second you take it out of that gear it has the same problem. Anyone that can help with this issue or tell me what to fix would be greatly appreciated!
