X6StringerX
- June 19, 2006
- 2011 Lincoln MKS EcoBoost
I just introduced myself in the "noob" section of the board and made a note in my initial post that I was going to post a tire fitment related question soon. I completed a search and read through the sticky and some other threads, but my question is still unanswered.
I had a '97 XLT 4.0 4x4 Explorer a couple years ago. I put 31x10.50x15's on it and they rubbed on the A-arm when I cut the wheel. The shop I was dealing with was kind enough to exchange them for 30x9.50x15's and all was fine. BTW, these tires were Kumho Venture A/Ts.
I have a different situation now. I have since traded the '97 off and I just purchased a '98 XLT 5.0 AWD a month or so ago. The '98 has a different style wheel. I was more into off roading with the '97, hence the ATs. The '98 is going to be on the street 99% of the time, but I don't plan on buying different wheels or anything like that. I basically just want a performance street tire and at the same time, give it a slightly different look by going with something a little wider and "maybe" a little taller. I've picked out the Falken STZ04 tires, but I'm a little confused about the size I can run with my stock wheels.
I've done some calculations and research on the actual dimensions of the following tires:
Stock 235/75/15 ----> 28.87"/9.25"
255/70/15 ----------> 29.05"/10.03"
255/75/15 ----------> 30.05"/10.03"
30x9.50/15 ---------> 29.99"/9.48"
31x10.50/15 --------> 30.97"/10.51"
The two pictures I'm going to post below are examples of the wheels I had/have. The first picture is of the '97's wheel. The second picture is the '98's.
Could you guys please help me out? I'm not sure if the front suspension on the AWD vs. the 4x4 is the same... is it possible to fit a 31x10.50/15 on the '98 AWD with its current wheels without rubbing? If not, which of the above mentioned tires can fit on it without changing the wheels or altering the suspension in any way? Its important to me that there is no rubbing whatsoever. Oh yeah, the two types of wheels in question... do they differ in backspacing? Width? Anything? Or are they just different styles? I really appreciate any insight you guys can give on my situation.
