jtison
- December 20, 2004
- W Connecticut
- '94 XLT/155 Kmiles 4x4
Oh boy. I've got a hole in the muffler, time to replace it. As long as I'm back there, I'm thinking about doing an entire catback system -- I'm certain (3rd owner of this '94 XLT) this is all original exhaust. AFAICT, the system from the cat forward to the manifold doesn't leak, and it passed its last emissions inspection (January '05) with flying colors.
The muffler doesn't look like a "standard" muffler ... there appears to be a heat shield or something attached to it ... it has a bunch of latitudinal ridges. True or false? All the OEM replacement mufflers I find on the 'Net look standard: plain old flat sheet metal, normal elliptical shape. Hrmm. The Maremont replacement mufflers say to reinstall the OE heat shields ... this is gonna be quite a mess if what I'm looking at is indeed the heat shield(s): it's badly corroded. Any advice/ideas? (If there's really a requirement for a heat sheild, how/where do I go about finding it and installing it?)
The most important question I have is the OEM exhaust pipe width from the cat flange back. I put my caliper on it, and it reads 2.158" OD (outer diameter) -- that's an odd size. Would this size of pipe be considered 2"? It's quite possible that all the corrosion on that pipe might be adding to the observed diameter.
The next question I have: I'm sure there are plenty of others on this board (as usual, thanks be to you!) with experience and advice about what to do about catback systems. I'd really like to find something stainless steel and as low-backpressure as possible. Suggestions? (PS: I don't weld, but I'd like to do as much of this myself as I can)
TIA, folks. This board is great
