Oil dipstick tube removal HELP! | Ford Explorer Forums
fordsRfun
hailey, ID
97 awd v8 xlt
In the process of removing my driver side exhaust manifold to install TM headers. How do I remove the oil dipstick tube? I feel like a dipstick having to ask this:) Anyway, I am gonna go start on the passenger side, will check back in a bit.
VICTORY I got it!! More dumb questions to follow as I umble my way through this install:)
Try to find an o-ring to fit the end of the dipstick, or else use a good RTV to seal it at the block. It will leak otherwise.
I'm having Trouble installing my Oil Dipstick Tube
There is a Lip or Overhang on the Engine Block ....Blocking the Hole / Opening to the Oil Pan
See Pic
The Red Line is the Lip / Overhang I'm referring to.
Do you recall running into this ?
