oil gage/check gage
hi mates,
mine is doing the same thing now that the weather is getting cooler. I checked it out pretty well and all seemed OK, I removed the oil filter and had a friend start the engine while i looked underneath at the oil filter location, well it pumped out oil like a gushing well, So the pump is fine, The only thing it could be is the sender unit,Its not realy a pressure gage, its just a switch that reads on or off, when it reads on the gage goes to the middle of the hi / lo. So if you have 2 litres of oil it reads OK, If you have 6 litres of oil it reads exactly the same IE half way. Of corse you will have to have it replaced,I was quoted $70 at Super cheap autos and $32 at the local auto mechanic for a new sender and half an hour labour. Well the switch is so easy to get at labour should be about 5 minuts. Looking at the engine from the front you will see the sender on the bottom right (batery side)at the front of the engine , it has one wire connected to it, from memory its white. So dont pannic about driving if the gage is comming up, if after the usual time it dosent work then STOP straight away.
