soccerella
- October 21, 2007
- norfolk, va
- 2000 V8
Hey everyone,
I have a 2000 explorer, V8, AWD. I bought this used at the end of August, and took it to the Ford dealer down the street from my house friday for "the works" to be done to it....check battery, change oil and filter, rotate tires, check hoses and brakes, etc. They ended up chaging the oil and filter and replacing power steering fluid. My battery needed replacing, but I did that myself instead friday afternoon.
Saturday morning, on my way back from the grocery store, the oil pressure gauge dropped to zero. I had just turned onto my steet, so I continued the 100 or so yards to the house. The pressure gauge was going back and forth between zero and middle, and the check gauge light came on. When I pulled into the driveway, the car started to make a slight noise right before I turned it off.
I checked under the hood and it smelled a bit off. There was oil everywhere, all on the drivers side under the hood. It looked like it had actually sprayed. There was still oil in the car when I pulled in the driveway, but now it seems to have leaked all over the driveway. I called the ford dealership and they towed it back there and gave me a rental until someone can look at it on monday.
Question is, what do you think happened? Is it likely they messed up somehow doing the oil change as this happend less than 50 miles after they did it? Or is it a huge coincidence and an expensive fix for me?
Thanks for your help
