91 xlt lifter clatter oil pump prob
I have had lifter clatter for about 2 years now, off and on to start, now it is constant. Occasionally at idle it will get quieter, then louder, then quieter. The last few months I have had an oil pressure guage that reads normal if I rev or am driving, but at idle it hovers at the low side of the guage. I thought I had a faulty sending unit and was not worried about it. I wish I had worried a bit more.
One night when I started it up to come home from work, almost immediately after starting the engine I heard something spraying out under the X. I looked under to see, in horror, that it was engine oil. I shut it off immediately (after crawling under I found that I had lost all but about 1/2 to 1 quart). I found the filter was where the leak (spray) was. I tried a new filter. When I started it, the filter bulged out and I heard a pop, followed by more spraying oil (from the filter to engine connection). My best diagnosis is that the lifter noise was caused by low oil pressure, and that eventually the pressure relief failed and/or outlet on the pump became completely clogged, and the pressure buildup popped the filter off the housing.
I am in the process of yanking the engine to replace the pump. I hope I do not have too much damage to the rest of the engine.
Watch that guage! Get a real one installed for safety. I wish I had known that lifter clatter was often indicative of low oil pressure.
Any comments or suggestions welcome.
And I thought my X was more reliable than my ^%^%$ SHO (love the car, but has left me stranded twice many miles from home).
