One of a kind still dead | Ford Explorer Forums
Post number 8 has been selected as best answered.
JohnBlackWolf
Guilford Indiana
1995 Ford Explorer Sport
New fuel pump new coil cleaned pin connectors 1995 Explorer starts great goes about a quarter mile dies suddenly 32 to 38 lbs fuel pressure ideas ,
Dies suddenly as in power loss like electrical? Don you lose the dash and everything? That would point to battery cables
If the engine just dies and then will start up again in a few that points to crank or cam sensor.
Could also be bad resistors in the pcm itself
If you can next time this happens check for spark, that will narrow things down
I put new crank sensor on , l did loose everything on dash, just ordered INNOVA 3145 OBD 1 code reader , should have gotten one before now , thanks for advice
Battery cables and connections are suspect
Pcm/eec relay also suspect
I did clean up the battery cables and I'm not sure about PCM never even heard of one going to ask a friend to check it , Google said it's behind battery
As these computers get older and the engines lose sensors the pcms can fail, some of the power capacitors will expand and go out. Also corrosion issues on the connections and solder joints. The pcm in a 95 is mounted on the firewall below the passenger side wiper blade
Fuel filter change did you?
Reply from @JohnBlackWolf 3/20/24 (From new duplicate and deleted thread)
Finally got odb 1 scanner said low current to MAF , 2 out of 4 wire's were burned almost in half spiced back together and , on the road again, thanks for asking the help
