Meat_PoPsiclez
- April 13, 2014
- Selkirk, MB
- 1997 Explorer Sport 4wd
Last weekend while wheeling someone pointed out my camber was off on my driver side, it was a touch out before (stock adjuster is maxed out) but acceptable, however it looked real bad.
Got it home and did a bit of diagnoses, came to the conclusion my drivers side upper bj is worn and has some play.
Today I pulled it into the garage to have another look, and the geometry seems good.. buuuut the drivers side front is sitting a good 3/4" lower than the pass.
I'd be inclined to assume the torsion bar is weak, the adjusters are maxed out and I run without the sway bar so the front end gets a lot more workout than normal.. but that doesn't explain why it looked different a week before.
Could a small amount of play in the bj explain this? Is it possible the torsion bar pad is worn and getting displaced? It saw some (read: a lot) of three wheeling last weekend, so if anything was going to get stuck behind the pad, that'd be the time it would have happened.
Insight?
Insight?
