outer tie rod end,how to?? | Ford Explorer Forums
jose22
New Mexico
99 XLS 4.0 OHV
Does anybody know how to change outer tie rod ends, all I see in this forum is how change inner,so any manual,instructions etc, would be very appreciated,thank you.
Um,, I didn't think a write-up was really necessary...
Remove the cotter pin, remove the retaining nut, whack it with a hammer to remove it from the knuckle, then loosen the jam nut where the inner tie rod end meets the outer end, and unscrew the outer end.
Reverse to install and have it aligned.
Does that help?
Sure It helps, is my first time doing this, so I didn't know How easy this was,thanks.
Just a note: Loosen the jam nut on the outer end before removing the end from the knuckle... It's easier if the whole assembly isn't flopping around.
-Joe
Take some pictures, and make a how to article.
I'm with gijoecam I don't think a How to article is really necessary, because this is an easy procedure compared to the other how to articles in here,But thanks guys.
