Outside Door Handle Loose | Ford Explorer Forums
bennythejet
Sprinfield, MO
1995 Eddie Bauer
The driver side door handle became loose all of a sudden. It still works but you just barely have to lift it to open the door and it wiggles when you shut the door. Anybody had this problem before? How do you tighten it up??
Read this thread..
Dead Link Removed
Sid
I have the same problem. Also, when my window is down i have a rattle when I shut the door. When the window is up, no rattle. What could that be?
I've got the same problem. There are two torsion springs that hold the tension on the latch. Over time, apparently they can break. I've got the new handle, just haven't had the time to drill the rivits out and replace it.
-Joe
