Outside temperature sensor failures..'97 XLT. | Ford Explorer Forums
skywagon
Grants Pass, OR
'97 XLT
A question from this newbie...
My '97 XLT has the outside Temp display in the center rear view mirror. It has failed numerous times and its failed again, usually the sensor. It has the temp sensor mounted in a nasty location on the frame and lower radiator corner.... a nuisance to change. The last time the dealer sent me the wrong unit.
Has anyone in the Group had a similar problem and found a better, longer lasting solution.... Thanks for any suggestions.
