Overhead Compass Help | Ford Explorer Forums
00GT99XLT
Arlington,WA
1999 Explorer XLT
1999 Explorer XLT
Bought it used knowing the overhead compass was out. Any ideas on a fix or should i just pull one from a junkyard? Also, it has an aftermarket Alpine cd player, i pulled all that out and looks like a pro install.
Any ideas would be great!
Also, my drivers side door lock does not pop up , nor down. LOL is that pain to fix?
Sorry for the newb 20 questions. Thanks guys,,,, and or gals :D
Mike
Both of those issues involve checking wiring for shorts or opens. For the compass: see if you have power at the compass module. For the door: See if you have power at the door lock switch.
You may need a wiring diagram.
Thanks! Yea i need to buy the book for this thing. LOL and a test light!
Look into factory service CDs or DVDs on EBay. They are very comprehensive. I can't imagine owning a car without that!
Fixing overhead compass
Much as I'd like to take credit for something I did not do.
The fix I got for my overhead compass/temp guage was found here. It involves removing the overhead compass and then disassembling it until you get to the circuit board. There you will find several small ( very small) square circuits components ( dunno what they're called ) that have the nasty habit cracking at the solder joints ( from car vibrations and shocks ) and in need of resoldering. I had to do this twice because I did not properly solder them the first time I did the removal and disassembly.
Its a bit of a pain to disassemble and reassemble ( a 7.5 out of ten.., at least to me ) take your time to see how it comes apart so you can know how to put it BACK together. Take your time!!
ONLY USE A SMALL RADIO SHACK 15 Watt soldering iron and make sure the tip if filed so that it comes to a fine point. This will help to ensure a precise solder in the small area that needs resoldering.
As I said , the fix is here, but I don'te remember where, and there might even be pictures. I fixed mine and I'm no expert at anything.
The dealers will charge you the earth to fix this device.
Good luck
Dude ive been looking for info on that since i got it and this has to best thing ive read to date! :thumbsup: THANKS i will try it tonight! dissassembly that is. LOL :D
Mike
Overhead compass
Mike,
My pleasure , but the info is on this website, I;m just an idiot for not remembering where I saw it. If you also do a Google search using
" Overhead Compass, Ford Explorer" you might find a detailed set of instructions.
I'll try to help as best I can if you get stuck.
Randy
That was the problem! there was a loose lil thingy. Unfortunatley i cant solder to save my life and i ruined the board. :mad: Time to hit the junkyard!!!!
Thanks alot for the point in the right directions! :thumbsup:
Mike
