Compass Calibration Adjustment
Start the vehicle. NOTE: For optimum calibration, drive to an open, level location away from large metallic objects or structures. Switch off all non-essential electrical accessories (rear window defrost, heater A/C, map lamps, wipers, etc.) and make sure all doors are closed.
Locate the electronic compass/temperature display on the overhead console, press and hold the MODE button until CAL appears in the display, then release the MODE button. NOTE: To exit CAL mode before performing a compass adjustment, turn the ignition switch to the OFF position.
Drive the vehicle slowly (less than 5 km/h [3 mph] ) in complete circles until CAL disappears from the display. NOTE: If the CAL indicator does not turn off after the vehicle has been driven in a circle no more than five times, demagnetize the vehicle and repeat the procedure
