bsquishy
- February 9, 2009
- waterloo, ia
- 96 eddie bauer
I have a 96 explorer 4L and it has been sitting for several months now because of overheating and no $$ to do anything about it.
I've used the blend door trick (cutting a hole....) and that worked for over a year but then it began overheating.
I didn't notice any window fog or smell, or any leaking on the interior. So I don't know where to start.
The thermostat was replaced, no change, the blend door was right where it needed to be. I was experiencing a leak from somewhere near the firewall but seeing as how I was driving, I couldn't tell exactly where it was coming from.
When I checked my rad/overflow they were both empty so I filled the rad with 50/50 and drove about 5 miles and it began to overheat again, and the rad was empty and so was the overflow. At this point I also noticed that I wasn't getting heat. I filled it again to get me home and it didn't overheat on the way home at all, then I drove around the block a few times and it seemed fine. I checked the rad and it was empty again. So I filled it and let it sit over night. When I came out again, there was still coolant, drove it around the block a few times and it leaked out, I had no heat, and it overheated.
How can I tell if it's the heater core, the radiator, or the heater control valve?
Any help is greatly appreciated.
Thanks.
Thanks.
