03explorermike
- August 9, 2009
- bellingham wa
- 03 explorer sport xlt
ive spent alot of time searching the forum but with no luck, i have a 03 sport xlt 6cyl that im stumped on. its hard to start when its 45f or less and have to give it gas to start. on start a poof of black smoke and exhaust smells like unburnt gas. it idles at 500-550rpm and runs a little rough and if i tap the throttle pedal it usually dies. when driving and climbing hills when there is load on the engine there is a slow power surging as if i was slowly letting off then pushing on the gas. drivability seems to be good until it started dieing at stop lights. it smells rich all the time. im getting about 11mpg.
i checked for vacuum leaks with starting fluid and found none. i tested the egr and its working. i cleaned the maf sensor with "maf clean" with no effect. the fuel pressure is 68psi. chilton says 28-45psi?. i have not thrown any parts in it yet because im trying to find whats bad. at this point i wish i had a obdII scanner but am hoping someone knows whats wrong.
maf sensor?
fuel pressure regulator?
Thanks for any help or advice!
maf sensor?
