Jim Jermain
- February 20, 2006
- Madison, WI
- 00 XLS
Recently my '00 4.0 OHV Explorer (74K miles) recorded a P0303 misfire on the # 3 cylinder. It set the code right at start up when I tend to get a rough idle for only about a minute. I have changed the upper intake plenum gasket and after it set the code I pulled the fuel rail, replaced the fuel rail gasket and all the injector o-rings. I tightened up the fuel rail studs and also torqued the intake manifold bolts to the proper spec. After I put it back together it ran perfect for one week. However after a week my rough idle is back at start up. It has not set the DTC. However I suspect that is coming. I'm thinking it is either a bad fuel injector or a bad lower intake manifold gasket. Any suggestions on trouble shooting?
I've tried pulling the #3 plug after the car sits overnight (when the rough idle is the worst). I did not notice any gas or antifreeze on the plug. I also tried pulling the plug wire and cranking over the engine to see if maybe there was gas or antifreeze down in the cylinder and would fowl the plug at start up. I couldn't see anything.
I really appreciate any tips.
Thanks,
Jim
Thanks,
Jim
