JJC
- June 28, 2018
- 2005 Ford Explorer XLS
My check engine light just came on yesterday. When I got it checked it said it was a problem with the egr sensor not detecting enough flow. I had replaced the egr line due to it leaking and have noticed nothing leaking since. I also replaced the egr valve gaket. The only other symptom is that the engine hesitates. I have a 98 explorer xlt 5.0l v8.
Update: I have noticed since the light came on that it takes a little longer for it to start after turning the key.
Update: I am able to test the voltage, but I don`t know what the voltage is supposed to be. When I do a google search I get mixed results. Could anyone help me out?
Update: I decided to take it to an auto shop and have them check it out. One of the nipples on the egr control solenoid was broken, and that was causing the issue.
