Pad change issue | Ford Explorer Forums
Pad change issue
Changed the pads and rotors on my 2016 explorer today (z36 and centric premium).
The new pads have clips/springs on the side of the pads I assume to keep them off the rotors and cut down on rattle. The old pads did not have these.
Once installed and drove around I noticed the springs/clips are pulling the pads off the rotors like 1/4th of an inch. I am going to assume that is not normal and will just cause more travel in the peddle before stopping.
Can I just pull them off and cut the clips/springs off to match the old pads?
Not sure how to visualize what you're describing. Can you take a picture or describe it better. The clips give a polished, clean surface for the pads to slide in on the carrier. Carrier can get pretty rusty. They also have an orientation to them, have to be put in correctly.
NVM im an idiot, disregard original post.
