Brem95
- September 7, 2019
- Location
- Canada
- Alberta
- 97' Explorer Sport OHV
Good evening, I hope everyone is doing well. Currently it's -35-40+ degrees here in Canada so I've been letting my 97' explorer sport start 15 or so minutes before work. My parking brake has finally gave out and I am forced to leave the truck in gear then when I start the vehicle back it down in neutral until it's on flat ground.
I just pulled it into the garage and about to jack it up and take off the rear wheels to inspect, just wondering if this is the best route to go:
1. Open up rubber plugs on rear discs to see if the star adjuster is seized or not (If it's not seized which direction do I turn these? I saw differing facts online
2. Inspect cable for slack or breaks
3. remove drums and inspect, clean and or replace the hardware and shoes
Thanks hoping to at least diagnose the parking brake system so I can fix it before I end up rolling into someones vehicle while I'm letting it warm up!
T.I.A.
Unrelated but worth a shot, when it's cold is it normal to have stiff left and right steering even after letting the vehicle idle and driving it for 10-20 mins? Power steering fluid was changed in the fall.
T.I.A.
