Pass. Lowbeam and Driving Lights Out | Ford Explorer Forums
DragSpeed
St. Louis, MO
'95 Eddie Bauer
I just bought my Explorer in july and it is a 95 Eddie Bauer. The stock driving lights have never worked, and the passenger side low beam just went out two days ago but the pass. side high beam works. How would i go about fixing the driving lights and is the headlight just a bulb could there be something else wrong with it.
Your driving/fog lights may just have burnt out bulbs as could your headlight.
For the fogs just lay on the ground, reach up and the bulbs twist out. Note that they only come on with the low beams.
For the headlight you may have to remove the air cleaner to get your hand in there to change the bulb (9007). If it still doesnt work & you have a message center instead of storage bins check the FAQs for Lamp Out Module.
Cool, thanks. I wasnt sure if any of it could be related to the Lamp Out Module and i wouldent want to spend money of a new bulb if that wasnt it.
I got it, it was the LOM. Thanks for the help.
