Passanger Power Window-down, no up | Ford Explorer Forums
guzzler528
Milton, MA
97 Sport
Happy Holidays to all
I sold my 88 Grand Wagoneer and bought a 97 Sport. Awesome little rig.
My problem is the passenger side window will go down but not up. Investigation revealed the motor getting 14 volts going down and 5.6 volts going up. Any Ideas? I'm thinking the drivers side switch is bad.
Thanks in advance
EDowling
"I don't advocate the use of alcohol, drugs and violence, but they've always worked for me" Hunter S. Thompson
There are a lot of switch problems
My window lockout is flakey. It has to be switched to lock and then back again. Had trouble with passenger side locks due to rain getting in on the connectors. These are very weak metal contacts. If you remove the connector for any reason, you need to go in with a tool like an ice pick and bend them back in. My contacts were corroded and this could be where you are getting the voltage loss.
Having the same problem....
My rear passenger side window goes down, but not back up also... Do you have any pictures or realllllllyyyyyy idiot proof instructions I can do to fix it. Does it have to do with the driver -master window lock as I tried to make sure it wasn't locking the window.. or does it have to do with the passenger window switch itself??? Any help would be great. Thanks,
CpuVampire@Hotmail.com
- Joe
