passenger wheel is leaning inwards | Ford Explorer Forums
explorerdogg
i have a 97 2wd v8 explorer an my front passenger wheel in leaing inwards what can cause this an what could possible have to be replaced this was noticed around the time when i had my mechanic change my rotar on that wheel the drive side wheel is fine let me know if u need more info
Ball Joint, or wheel bearings could be the culprit. Or the camber adjustment got knocked out of whack somehow...
is this expensive to have fixed what kind of shop should i try taking this too, thanks for your quick response i almost sold the x but now im going to do a complete over haul thanks
Well if it's just the wheel bearing you could do it yourself, or any shop can of course do it. If it's the camber is just screwed up somehow or the ball joint I think that your best bet would be a shop with an alignment rack...i'm pretty sure that when you replace the ball joints you'll have to get an alignment and of course you'll need one if just need a camber adjustment. It shouldn't take all that long.
Good luck!
CP :D
thanks u guys are great i will take it to an alignment shop in the morning i just put new tires on it so it needs an alignment anyway i was just wondering how many hundreds of dollas is this going to cost me i just recently had the tranny an engined rebuilt
