Sramsey232
- March 1, 2011
- Detroit, MI
- 01 Ford Expl Sport Trac
Where does the antenna on the module for the key code plug into on the ignition? Theres a black and a black and white wire that isnt plugged in to anything and if that came unplugged, could it have erased the key code? Cuz ive read that if the PAT system wasnt getting a signal that it would take away the ground from the starter relay, and wouldnt initally give 12 volts but only 6 volts to the inertia switch. And whats happening. Thanx for your time and help.
