h82loseejr
- October 18, 2017
- Location
- Pleasantville PA
- Pleasantville
- 05 Explorer XLS
I am not going to go into detain on remote start install. There are plenty of articles covering that. What I am going to cover is how to bypass PATS or chipped key to install remote starter without purchasing a bypass module . I live in a rural area that I am not worried about bypassing the chip in the key. If you do this then the vehicle can be started with a key that does not have a chip in it.
We only had 1 key with our explorer so adding another key for a bypass module would involve a trip to the dealership. So instead of paying the dealer and then purchasing an expensive bypass module for a system that we really did not need I decided to bypass it myself.
All I did was take our 1 working key to Walmart and had 2 keys cut. Took some convincing of the clerk who told me that because that key had a chip in it if I tried to start my vehicle with it it will fry my computer and she knows this. After reassuring her that I know what I want and am well aware of the risk she cut my keys for me.
I took the covers off of steering column and I removed the transponder receiver. It is located around the ignition. It has one screw (5.5 mm) that is located on bottom of the module. I used a pry bar I got it on top of the cable tray and got it to pull down. (do not pry on the module you will break it and then your vehicle will not start at all. Once the tray comes down you can access the bolt for transponder.
I took the original chipped key and moved it around on the receiver to find the proper spot that the car would start with the Walmart key. Getting the key close to it was not enough. It took some time to find the sweet spot. I then took electrical tape and held it in that exact spot....I re routed the wires to under the steering column to get it out of the way of the shifter linkage. DO NOT DAMAGE THE RECEIVER OR YOUR CAR WILL NOT START
