Paul, question on your differential article... | Ford Explorer Forums
Fredness
Tejas!
'05 Sport Trac Adrenalin
Paul Gagnon, Q's regarding Differential Swap Article...
Great job on the article, but I'm doing the same for a '94 Splash. Should I use the Explorer springs and lower shock mounts or should I "flip" the differential spring perch and use all Ranger stuff transferred from my orig. Diff.? I found a 4.10 L/S Disc rear from a '98 in the boneyard and they want $600. It's cheaper than and Auburn/New Gears/disc brake mod but ouch! <removed no longer used email address>
