PCV location? | Ford Explorer Forums
PCV location?
It's on the driver's side valve cover near the firewall. There is a vacuum line running off of it to the intake.
I will see if I can find a pic. Give me a few minutes.
this is an excerpt from my instructions, this is what i need help on!
"Under the hood, choose an easy to reach space for the PCV Enhancer. The device itself needs only a small space - but remember that you'll need access to check the contamination level and also be able to reach it with your hand for cleaning.
The best position would be below the level of the intake manifold (to enable water to sink into the device after the engine has stopped, rather than dripping back into the engine). Due to its plastic parts it is also recommended to keep the PCV Enhancer away from engine heat as much as possible, but no more than 2 feet away.
I chose a location at the of level of the PCV and easily accessible from the side of the car, near the brake drum."
Here is a picture I took standing by the driver's side fender looking at the engine. The pcv valve is circled in red.
Honestly I am not sure because I've never seen the engine bay of a 93. Hopefully someone that has a 93 will chime in. But I would imagine it to be very similar with the exception that a 93 has an egr valve so there might be more hoses around there making it look more complicated. But other than that I would think it would be in the same place on all first gens.
