PDF Tranny Manuals | Page 13 | Ford Explorer - Ford Ranger Forums - Serious Explorations
PDF Tranny Manuals
blazin8556
Stalkin' your mom....
1997 XLT AWD 5.0
i clicked on the wrong thing. its downloading now. sorry.
cammo
christchurch,nz
lots
Aw50-4* box + fundamentals book
hi can you post the autotransmission fundamentals book (ive only got 45%) and a book for aw50-40/2/le.
thanks
also a minimum tool list for trans overhaul(assuming you can use sockets to press in seals etc) over a comprehensive mechanics kit.
cheers
cam
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
KLYVON
Trinidad & Tobago
!985 Mazda 626 GC Coupe
Needing mazda F3A tranny manual
Here is a current but partial list of tranny manuals I have. PM requests for magnet links:
Hey man may i request a download link to one of your manuals it the F3A mazda 626 GC 1983-1987 model thanks
General Motors
TH125 Transmissions - TH125 (M34) 3T40, TH125C (MD9)
Saturn TAAT - Saturn Transmission - TAAT - FWD 4 Speed
A210, GM MX17 - 3 Speed FWD
TH180 Transmissions - TH180 (MD3) 3L30, TH180C (MD2)
4L40E - 5L50E Transmissions - 4L40E 4 Speed 5L40E 5 Speed (M82), 5L50E (M22) Electronic - RWD
TH200 Transmissions - TH200 (M29) TH200C (MV9)
TH200-4R - TH200-4R (MW9)
MK2, MK5 - MK2, MK5 - Corvette Overdrive, GM Overdrive 4 Speed
TH325 Transmissions - TH325 (M32), TH325-4L (M57) w/ Lockup
TH350 Transmissions - TH350/350C, TH250C/375B
TH400 Transmissions - TH400 (M40) 3L80, TH375 - TH475 3L80HD
4L80E/85E Transmissions - 4L80E (MT1), 4L85E (MN8) - 4 Speed w/ OD
4T40E/45E Transmissions - 4T40E (MN4), 4T45E (MN5) - 4 Speed Turbo Hydramatic
TH440-T4/4T60 Transmissions - TH440-T4 (ME9) 4T60 - 4 Speed - FWD
4T60E/65E Transmissions - 4T60E (M13), 4T65E (MN3, M15, MN7 HD) Electronic - 4 Speed - FWD
4T80E Transmission - 4T80E (MH1) Electronic - 4 Speed - FWD
Allison LCT - Allison LCT 1000/2000/2400 (M74)*
Allison AT540 Transmissions - Allison AT540, AT543, AT545*
Allison MT/B 640 Transmissions - Allison MT/B 640, 643, 644, 647, 650, 653, 654*
TH700-R4 & 4L60/65E Transmissions - TH700-R4 (MD8), 4L60/4L60E (M30), 4L65E (M32)
Powerglide - Powerglide - Aluminum Case
ST300 - Super Turbine 300
TH425 Transmission - TH425 (M40E)
GM Screens/Filters - General Motors Timble Type Screens/Filters
*--All I have are the parts books right now, not the full re-build manual.
Ford
C3 / A4LD Transmissions - Ford C3 (3 Speed) A4LD (4 Speed)
4R44E thru 5R55E Transmissions - 4R44E(2.3, 3.0L), 5R44E(2.3, 3.0L), 4R55E (4.0L), 5R55E (4.0L)
5R55N/S/W Transmissions - Ford 5R55N, 5R55S, 5R55W
C4/C5 Transmissions - Ford C4, Ford C5 - w/ Lockup
C6 Transmission - Ford C6
CD4E Transmissions - Ford CD4E, Mazda LA4A-EL (4 Speed - FWD)
E4OD Transmissions - Ford E4OD, 4R100 (4 Speed OD - RWD)
ATX Transmission - Ford ATX Transmission
4F27E Transmissions - Ford 4F27E (FN), Mazda J39A (FN)
AXOD/E Transmissions - Ford AXOD/E (AX4S) AX4S-HO Overdrive
AX4N Transmission - Ford AX4N (4F50N)
AOD/E & 4R70 Transmissions - Ford AOD (FIOD) AOD-E (Electronic), 4R70W/4R75W, 4R70E/4R75E
Fordmatic Transmissions - Fordmatic 3 Speed, Iron Case (Small, Medium), FMX
Ford Screens/Filters - Ford thimble type screens / filters
Chrysler
A-500 / TF-6 Transmissions - Chrysler - A-500 (40/42RH; 42/44RE Electronic), TF-6 [A904 (30RH) A998 (31RH) A999(32RH)]
A518/618, TF-8 Transmissions - Chrysler - A518(46RH/RE), A618(47RH/RE, 48RE), TF-8(A727 - 36/37RH)
545RFE & 45RFE Transmissions - Chrysler - 545RFE - 5 Speed, 45RFE - RWD/4WD - Fully Electronic 4 Speed
A404/413, A470/670 Transmissions - Chrysler - A404(30TH), A413, A470/A670(31TH) - FWD
A606 / A604 Transmissions - Chrysler - A606 (42LE), A604 (40/41TE - FWD, 41AE - AWD), RWD (42RLE)
Imports: KM170-177, F4A / AF Tranmissions - Imports: Chrysler(KM170-177), Mitsubishi(F4A-33), Hyundai(AFAF1-AFBF3)
Imports: RFA / V4A51, R5A / VA51 Transmissions - Imports: Chrysler/Mitsubishi/Hyundai - RWD (4Spd)RFA/V4A51 (5 Spd)R5A/VA51 - FWD
BW8 / 12 AMX - Cast Iron, Flash/Flightomatic - Chrysler - BW8, BW12 AMX - Cast Iron, Flashomatic/Flightomatic
BW T35/41/44 & Aluminum Case Flash/Flightomatic - BW T35/41/44 Transmissions & Aluminum Case Flash/Flightomatic
Honda
HONDA - Hondamatic 2/3 Speed
HONDA - Filters & Identification Charts
Mazda
F3A Transmissions - Mazda F3A, Ford Imports - 3 Speed, F3A- Jatco, GM R cars
F4A Transmissions - Mazda F4A-EL - FWD, F4E-III, Ford F4EAT - 4 Speed
G4A Transmissions - Mazda G4A-EL/HL, GF4A-EL - FWD, Ford - G4EAT 4 Speed
JF506E Transmission - Mazda JF506E - FWD - 5 Speed, Jaguar, VW
Mercedes Benz
Mercedes 722.0 to 722.6 Tranmissions - 722.0 to 722.6 5 Speed, Chassis ending 177-123 4 Bolt Pan/6 Bolt Pan, 3-4 Speed
Nissan
L3 / L4 / N4 Transmissions - Nissan L3N71B 3 Speed, E/L4N71 4 Speed, Mazda N4A-EL
RL / RE /R4 Transmissions - Nissan RL4R01A, RE4/501A, RE4R03A - 2/4/RWD, Mazda R4A-EL - 2/4/RWD
RE/RL4F02A Transmissions - Nissan RE4F02A, RL4F02A - 2/4WD, FWD w/ lockup
RL/RN3 Transmissions - Nissan RL3F01A, RN3F01A - 3 Speed w/ lockup
JR403E Transmission - Isuzu, Mitsubishi, GMC, Mazda, Nissan Trucks - JR403E - RWD Jatco Truck
RE/RE4F03/4A Transmissions - RE/REL4F03A Nissan, RL4F03V Sentra, Infiniti G20 - RE4F04A Nissan, RE4F04V Maxima,/Altima, 4F20E Villager/Quest, 4 Speed FWD, JF403E Storm, LJ4A-EL Millenia
Renault
Renault M Series Transmissions - Renault FWD 3 Speed Transaxle - MB1, MJ1, MJ3, 4139, 4141
Renualt A Series Transmisions - Renault, Eagle Premier - FWD 4 Cylinder - AR4, AD4, AD8
Renault DPO - Renault FWD 4 Speed Transaxle - DPO (AL4)
Borgwarner
BW-T35/37 Tranmissions - Borg Warner T35TB, T37TB, Saab FWD
W-T65/66 Transmissions - BrogWarner T65, T66 RWD, BMW Jaguar
BW-T35/41/44 Transmissions - BrogWarner BW-T35, T41, T44 (also in Chrysler section)
Subaru
M41 Transmissions - Subaru - M41, M41A, GUNMA - 3 Speed FWD, 2/4WD
R4AX-EL Transmissions - Subaru R4AX-EL (4EAT) 4 Speed - 2/4WD FWD 1st & 2nd Design
ECVT Transmission - Subaru ECVT Transmission
Toyota
A40 Series Transmissions - Toyota A40 Series RWD - Isuzu, Volvo, Mitsubishi
A340E Series Transmissions - A340E/350E 4 Speed - A650E/750E 5 Speed - A761E 6 Speed (Lexus)
A440 Series Transmissions - Toyota A440F, A442F, Landcruiser - Aisin Warner 450-43LE Truck - RWD 4 Speed w OD
A55 Series Transmissions - Toyota A55 Tercel FWD - A55F 2/4WD
A130 Series Transmissions - A130 Series 3 Speed - A140 Series 4 Speed OD - A240 Series 4 Speed UD - A540E/H, A541E 4 Speed OD
U140 Series Transmissions - Toyota FWD - U140E/F, U240E Series 4 Speed - U150E/U151E Series 5 Speed
U340E Series Transmissions - Toyota FWD - U140E/F, U240E Series 4 Speed - U150E/U151E Series 5 SpeedToyota U340E Series, U341E Series - FWD 4 Speed
Aisin Warner
AW50-40LE/AW60-40LE Transmissions - Aisin Warner AW60-40LE (AF13), AW50-40LE (AF14-20), AW50-42LE/LM
AW55-50SN Transmission - Aisin Warner AW55-50SN (AF33-5) 5 Speed
Volkswagen
010 Transmissions - Volkswagen 010, 087, 089, 090 - FWD 1 Band Type
003 Transmission - Volkswagen 003 - 2 Band Type Rear Transaxle
AG4 Transmissions - Volkswagen 4 Speed FWD Electronic - AG4-095/096/097/098, 01M/01N/01P
ZF
4HP14/18 Transmissions - ZF4HP14, ZF4HP18 - 4 Speed FWD
3/4HP22/24 Transmissions - ZF3HP22, ZF4HP22, ZF4HP24
5HP18 Transmission - ZF5HP18 - 5 Speed RWD
5HP19 Series Transmissions - ZF5HP19 RWD, ZF5HP19FL FWD, ZF5HP19FLA AWD - 5 Speed
5HP24/A Transmissions - ZF5HP24, ZF5HP24A - 5 Speed RWD
5HP30 Transmission - ZF5HP30 - 5 Speed RWD
6HP19/26 Series Transmissions - ZF6HP19, ZF6HP19A, ZF6HP26,ZF6HP26X - 6 Speed RWD
cammo
christchurch,nz
lots
hi there
ive had this trying to d/l for more than 3 wks...cannot get past 45%....no more packets available online?
or is your computer off ?
cheers
cam
BrooklynBay
Staff member
Moderator
Brooklyn, NY
Dukes62
Utah
Haven't had any luck with the 4R70W manual. My computer has been running non stop for over a week. Are these manuals still available?
BrooklynBay
Staff member
Moderator
Brooklyn, NY
adelyser
Are you still supporting the magnet links? I found 2 different C4 links, waiting for them to download metadata, or do you have different links now? If it's just a matter of waiting, I can deal with that. Thanks!
BrooklynBay
Staff member
Moderator
Brooklyn, NY
BrooklynBay
Staff member
Moderator
Brooklyn, NY
BrooklynBay
Staff member
Moderator
Brooklyn, NY
BrooklynBay
Staff member
Moderator
Brooklyn, NY
drn
CA
Do you have 2005-2007 Honda Oddysey/Accord manual? Both use a 5 spd automatic.
BrooklynBay
Staff member
Moderator
Brooklyn, NY
drn
CA
Any of these - BGRA /PGRA/BYBA/BAYA /MAYA? Hope this is what you are looking for.
Thanks
BrooklynBay
Staff member
Moderator
Brooklyn, NY
