PDF Tranny Manuals | Page 3 | Ford Explorer Forums
PDF Tranny Manuals
Ha. You know, We should probably sticky a new thread from post 17 down for using uTorrent....lol
It's a good idea, but one of the mods on this site once blasted me when I said the word torrent in a post to help somebody out. They don't like using them. Could you post a link for the Mitchell Transmission Manual?
Not yet....my source for it is not a torrent.....Gnutella can be slow....but IRC RoX! LoL. Anyway, ETA on the ENTIRE OnDemand System (which as you know covers way more than just trannies) @ roughly 85 Gigs across 26 DVDs, is some time Friday or Saturday. This will be a rather large release...the largest I've done that wasn't a rainbow table or other huge D-base. Due to it's size, plan on it taking about a year before anyone downloading it can get it within a week....lol.
As for PDF format books, it looks like I'm going to have to get out my Public Library card and get to work with my automatic scanner.....Guess who has several copies of many different Mitchell books? The Lawrence Public Library in Lawrence, Ks...less than a mile down the street from where my brother and I lived when I rebuilt the tranny the first time! LoL. I've seen these books before, and they did not let me take them out of the library....but they WILL send them to another library.....
Oh, and a note...there's nothing in the forum rules against using a program and talking about it. The FUD factor reigns supreme....Torrents and their use are not violative of any laws. In other words, "Chillax". LoL
New Magnet link...this one is for William Husselbee's "Automatic Transmission--Fundamentals and Service," 1986.
This is a MUST-Have text for anyone who wants a good solid understanding of the Automatic Transaxle.
Incidentally, this is a primary advanced textbook for THIS mechanics' school. Not bad for being 22 years old....
I've noticed on my torrent client that there are a few of you attempting to D/L the .PDFs. Great, but you need to have your client configured correctly for transfer. This isn't a main scene release, so it's not like you can depend upon a swarm of two or three thousand seeders to help you out; you must have your client set up right, and just because it's working a little bit doesn't mean it's working correctly.
The instructions above apply only to Micro-Torrent, but it's worth downloading if you use ANYTHING else. There is not one single BT client I've encountered in nearly ten years that beats it for reliability.
A couple of you are using Free Download Manager to download. This client is BLOCKED via the torrent settings because it disables seeding (which is returning to the swarm an amount of data once your download is complete, so that others find it just as easy to obtain the file as did you) by default, which means in order to be anything but a leecher, you must know to manually go into FDM and enable seeding through it's BT module.
Any questions about the program itself should be addressed here. Any requests should be PM'ed to me.
Here is a current but partial list of tranny manuals I have. PM requests for magnet links:
General Motors
TH125 Transmissions - TH125 (M34) 3T40, TH125C (MD9)
Saturn TAAT - Saturn Transmission - TAAT - FWD 4 Speed
A210, GM MX17 - 3 Speed FWD
TH180 Transmissions - TH180 (MD3) 3L30, TH180C (MD2)
4L40E - 5L50E Transmissions - 4L40E 4 Speed 5L40E 5 Speed (M82), 5L50E (M22) Electronic - RWD
TH200 Transmissions - TH200 (M29) TH200C (MV9)
TH200-4R - TH200-4R (MW9)
MK2, MK5 - MK2, MK5 - Corvette Overdrive, GM Overdrive 4 Speed
TH325 Transmissions - TH325 (M32), TH325-4L (M57) w/ Lockup
TH350 Transmissions - TH350/350C, TH250C/375B
TH400 Transmissions - TH400 (M40) 3L80, TH375 - TH475 3L80HD
4L80E/85E Transmissions - 4L80E (MT1), 4L85E (MN8) - 4 Speed w/ OD
4T40E/45E Transmissions - 4T40E (MN4), 4T45E (MN5) - 4 Speed Turbo Hydramatic
TH440-T4/4T60 Transmissions - TH440-T4 (ME9) 4T60 - 4 Speed - FWD
4T60E/65E Transmissions - 4T60E (M13), 4T65E (MN3, M15, MN7 HD) Electronic - 4 Speed - FWD
4T80E Transmission - 4T80E (MH1) Electronic - 4 Speed - FWD
Allison LCT - Allison LCT 1000/2000/2400 (M74)*
Allison AT540 Transmissions - Allison AT540, AT543, AT545*
Allison MT/B 640 Transmissions - Allison MT/B 640, 643, 644, 647, 650, 653, 654*
TH700-R4 & 4L60/65E Transmissions - TH700-R4 (MD8), 4L60/4L60E (M30), 4L65E (M32)
Powerglide - Powerglide - Aluminum Case
ST300 - Super Turbine 300
TH425 Transmission - TH425 (M40E)
GM Screens/Filters - General Motors Timble Type Screens/Filters
*--All I have are the parts books right now, not the full re-build manual.
Ford
C3 / A4LD Transmissions - Ford C3 (3 Speed) A4LD (4 Speed)
4R44E thru 5R55E Transmissions - 4R44E(2.3, 3.0L), 5R44E(2.3, 3.0L), 4R55E (4.0L), 5R55E (4.0L)
5R55N/S/W Transmissions - Ford 5R55N, 5R55S, 5R55W
C4/C5 Transmissions - Ford C4, Ford C5 - w/ Lockup
C6 Transmission - Ford C6
CD4E Transmissions - Ford CD4E, Mazda LA4A-EL (4 Speed - FWD)
E4OD Transmissions - Ford E4OD, 4R100 (4 Speed OD - RWD)
ATX Transmission - Ford ATX Transmission
4F27E Transmissions - Ford 4F27E (FN), Mazda J39A (FN)
AXOD/E Transmissions - Ford AXOD/E (AX4S) AX4S-HO Overdrive
AX4N Transmission - Ford AX4N (4F50N)
AOD/E & 4R70 Transmissions - Ford AOD (FIOD) AOD-E (Electronic), 4R70W/4R75W, 4R70E/4R75E
Fordmatic Transmissions - Fordmatic 3 Speed, Iron Case (Small, Medium), FMX
Ford Screens/Filters - Ford thimble type screens / filters
Chrysler
A-500 / TF-6 Transmissions - Chrysler - A-500 (40/42RH; 42/44RE Electronic), TF-6 [A904 (30RH) A998 (31RH) A999(32RH)]
A518/618, TF-8 Transmissions - Chrysler - A518(46RH/RE), A618(47RH/RE, 48RE), TF-8(A727 - 36/37RH)
545RFE & 45RFE Transmissions - Chrysler - 545RFE - 5 Speed, 45RFE - RWD/4WD - Fully Electronic 4 Speed
A404/413, A470/670 Transmissions - Chrysler - A404(30TH), A413, A470/A670(31TH) - FWD
A606 / A604 Transmissions - Chrysler - A606 (42LE), A604 (40/41TE - FWD, 41AE - AWD), RWD (42RLE)
Imports: KM170-177, F4A / AF Tranmissions - Imports: Chrysler(KM170-177), Mitsubishi(F4A-33), Hyundai(AFAF1-AFBF3)
Imports: RFA / V4A51, R5A / VA51 Transmissions - Imports: Chrysler/Mitsubishi/Hyundai - RWD (4Spd)RFA/V4A51 (5 Spd)R5A/VA51 - FWD
BW8 / 12 AMX - Cast Iron, Flash/Flightomatic - Chrysler - BW8, BW12 AMX - Cast Iron, Flashomatic/Flightomatic
BW T35/41/44 & Aluminum Case Flash/Flightomatic - BW T35/41/44 Transmissions & Aluminum Case Flash/Flightomatic
Honda
HONDA - Hondamatic 2/3 Speed
HONDA - Filters & Identification Charts
Mazda
F3A Transmissions - Mazda F3A, Ford Imports - 3 Speed, F3A- Jatco, GM R cars
F4A Transmissions - Mazda F4A-EL - FWD, F4E-III, Ford F4EAT - 4 Speed
G4A Transmissions - Mazda G4A-EL/HL, GF4A-EL - FWD, Ford - G4EAT 4 Speed
JF506E Transmission - Mazda JF506E - FWD - 5 Speed, Jaguar, VW
Mercedes Benz
Mercedes 722.0 to 722.6 Tranmissions - 722.0 to 722.6 5 Speed, Chassis ending 177-123 4 Bolt Pan/6 Bolt Pan, 3-4 Speed
Nissan
L3 / L4 / N4 Transmissions - Nissan L3N71B 3 Speed, E/L4N71 4 Speed, Mazda N4A-EL
RL / RE /R4 Transmissions - Nissan RL4R01A, RE4/501A, RE4R03A - 2/4/RWD, Mazda R4A-EL - 2/4/RWD
RE/RL4F02A Transmissions - Nissan RE4F02A, RL4F02A - 2/4WD, FWD w/ lockup
RL/RN3 Transmissions - Nissan RL3F01A, RN3F01A - 3 Speed w/ lockup
JR403E Transmission - Isuzu, Mitsubishi, GMC, Mazda, Nissan Trucks - JR403E - RWD Jatco Truck
RE/RE4F03/4A Transmissions - RE/REL4F03A Nissan, RL4F03V Sentra, Infiniti G20 - RE4F04A Nissan, RE4F04V Maxima,/Altima, 4F20E Villager/Quest, 4 Speed FWD, JF403E Storm, LJ4A-EL Millenia
Renault
Renault M Series Transmissions - Renault FWD 3 Speed Transaxle - MB1, MJ1, MJ3, 4139, 4141
Renualt A Series Transmisions - Renault, Eagle Premier - FWD 4 Cylinder - AR4, AD4, AD8
Renault DPO - Renault FWD 4 Speed Transaxle - DPO (AL4)
Borgwarner
BW-T35/37 Tranmissions - Borg Warner T35TB, T37TB, Saab FWD
W-T65/66 Transmissions - BrogWarner T65, T66 RWD, BMW Jaguar
BW-T35/41/44 Transmissions - BrogWarner BW-T35, T41, T44 (also in Chrysler section)
Subaru
M41 Transmissions - Subaru - M41, M41A, GUNMA - 3 Speed FWD, 2/4WD
R4AX-EL Transmissions - Subaru R4AX-EL (4EAT) 4 Speed - 2/4WD FWD 1st & 2nd Design
ECVT Transmission - Subaru ECVT Transmission
Toyota
A40 Series Transmissions - Toyota A40 Series RWD - Isuzu, Volvo, Mitsubishi
A340E Series Transmissions - A340E/350E 4 Speed - A650E/750E 5 Speed - A761E 6 Speed (Lexus)
A440 Series Transmissions - Toyota A440F, A442F, Landcruiser - Aisin Warner 450-43LE Truck - RWD 4 Speed w OD
A55 Series Transmissions - Toyota A55 Tercel FWD - A55F 2/4WD
A130 Series Transmissions - A130 Series 3 Speed - A140 Series 4 Speed OD - A240 Series 4 Speed UD - A540E/H, A541E 4 Speed OD
U140 Series Transmissions - Toyota FWD - U140E/F, U240E Series 4 Speed - U150E/U151E Series 5 Speed
U340E Series Transmissions - Toyota FWD - U140E/F, U240E Series 4 Speed - U150E/U151E Series 5 SpeedToyota U340E Series, U341E Series - FWD 4 Speed
Aisin Warner
AW50-40LE/AW60-40LE Transmissions - Aisin Warner AW60-40LE (AF13), AW50-40LE (AF14-20), AW50-42LE/LM
AW55-50SN Transmission - Aisin Warner AW55-50SN (AF33-5) 5 Speed
Volkswagen
010 Transmissions - Volkswagen 010, 087, 089, 090 - FWD 1 Band Type
003 Transmission - Volkswagen 003 - 2 Band Type Rear Transaxle
AG4 Transmissions - Volkswagen 4 Speed FWD Electronic - AG4-095/096/097/098, 01M/01N/01P
ZF
4HP14/18 Transmissions - ZF4HP14, ZF4HP18 - 4 Speed FWD
3/4HP22/24 Transmissions - ZF3HP22, ZF4HP22, ZF4HP24
5HP18 Transmission - ZF5HP18 - 5 Speed RWD
5HP19 Series Transmissions - ZF5HP19 RWD, ZF5HP19FL FWD, ZF5HP19FLA AWD - 5 Speed
5HP24/A Transmissions - ZF5HP24, ZF5HP24A - 5 Speed RWD
5HP30 Transmission - ZF5HP30 - 5 Speed RWD
6HP19/26 Series Transmissions - ZF6HP19, ZF6HP19A, ZF6HP26,ZF6HP26X - 6 Speed RWD
pm sent on c-4 and c-5 transmissions
The C-4 and C-5 are very much alike, so I've read. There are some differences such as the addition of a TC Lock-up clutch and some VB changes.....I will see what I can come up with....
C-4/5 PDF Manuals Here.
I will try to dig up something a little more inclusive.....There's got to be something better out there than these. Give me a while to do some checking around.
For the record, these are the ATSG C-4/5 manual and a separate parts list for same.
what magnet protocal do i need to use to open this, windows does not recognize this protocol and i don't want to download any thing that has any mal-ware or bugs
No such thing as a separate "Magnet Protocol". Magnet as a protocol, would just be the syntax of a magnet link: magnet:?xt=urn:btih:5LF4DF2QPCONSDN23P6RYNZYTW7KCMPY
You use uTorrent or Azereus or some other program capable of using magnet links. Read from post 17 down of THIS thread.
As for viruses, these are PDF files. There cannot be viruses in PDF files. Further, they are UN-LINKED PDFs, such that they do not reference any outside source (such as the internet) which could potentially be hazardous to the health of your PC.
Besides, these are my releases that I packaged or re-released from other sources, including some which are not on the internet. Which means they can't be Googled. I do not pack malware of any kind in any release. What kind of reputation would I have?
no i'm not saying any thing about you, i'm very glad you are allowing me the the chance to be able to use your pdf files. I'm just saying i can't open them
right now, somethings not working on my end. when i click the link it takes me to another screen and says to use live sreach to find a program to open it, and when i use live screach. It tells me that windows does not recognize this protocol. so i need to find out what is going on at my end so i can try to help the next person
That's what I'm saying: The link here on the site is a magnet link, not a torrent. You can go HERE and download
so that when you click the magnet link, your Micro-Torrent client opens and begins the process of downloading the PDF. The alternative would be for me to publish a new .torrent and cross-link it here in the forum, rather than simply posting a snippet of code that your torrent client will use to automatically begin the transfer.
Windows doesn't recognize the protocol because there isn't one. There is no extension on the magnet link.....the link is not a file, but because there is a period in the text, windows is deciding to interpret the link as a filename, which would imply there is a protocol for the construction of a file, but the link is not a filename because there is no file, hence no file protocol to even be found, much less recognized.....
Now say that ten times, fast.
thank you i found the link in post 18 on the other post, and downloaded the program and i'm now waiting to see what happens
it is downloading now thank you so very much, i just had to go in to options and connections and make sure every thing was checked and allow it to work
the ports right :thumbsup:
there's no way that i can say that 10 times real fast. i have enough trouble just re- learning to type now. after loosing a finger a month and ahalf ago
