Periodic Starting Issue | Ford Explorer Forums
mad_dog97
Richmond, VA
'04 EB
Need some help here. I have a 2002 Ford Explorer Sport Trac. I have two issues I am fighting. One the Idle is low, dips when shifting from Drive to Park. It doesnt stall, but drops to 200 -300 RPM and shudders. I have replaced the IAC, PVC valve, and the vacuum line attached to it. The second issue I am not sure if is related or not, but two times after shutting off for about 10 minutes the truck would not start - run. It started for a second, died and would not restart. Both times after cooling off about 30 minutes it would restart normally. Almost seemed it was vapor locked. Any thoughts on this problem?
Are there any codes, either current or history?
Thanks for the reply. No codes - or Check Engine Light.
