Tim K
- December 7, 2000
- Philadelphia, PA
- (former owner) '97 XLT
I have been reading up on the threads on "Ram air" and cold air induction, drilling airboxes, etc. I was thinking about running some hose from the bumper opening to the intake for a home-made "cold air induction kit". According to several users, they have run 2.5" or 3" diameter hoses up from the bumper opening in the front of the vehicle with good results.
So now you are saying..."what the heck does this have to do with physics????" Well, here is my question:
If I were to place 2 funnels in the bumper slot each connected to a length of 2.5" (diameter) hose....then connected those hoses to a Y-connector, which in turn was connected to more 2.5" (diameter) hose running to the intake...how would the air behave? "ram air" is rumored to only work at high speeds, and cold air induction helps most when you are moving. So I was wondering if this fits somewhere in between. I am just not sure how the air would behave.
I have 3 theories:
Assuming that when travelling 40MPH, the air entering the tubes would be moving at 40MPH (essentially).
A) 2 tubes with 40MPH air meet at the Y-connector and are forced up the 3rd tube at twice their previous rate (granted friction and so forth would slow it down somewhat).
B) the Y-connector causes an "air bottleneck" and the 3rd tube will not flow any faster in effect slowing up the 2 intakes.
C) the air is compressed in the 3rd tube, thus getting twice the oxygen to the engine but at the same rate (40mph) as the intake.
If theory A is correct, this would be a great way to get LOTS of cold air to the engine....Any Physicists out there?
I have 3 theories:
