Picture, 33's with a 4" lift?? | Ford Explorer Forums
Blackdog
Zillah Washington
2004 F-150, 2006 Ranger
I've been thinking about lifting an Explorer with a 4" Superlift and 33's. Anyone got a picture of this setup? Thanks
website is in my sig, running 32's
Looks good. Is the Superlift kit the best one out there? Are you happy with it? I plan on runnig 33's, I hope that tire clearance won't be an issue. Thanks
you'll clear 33's fine.
You might have some problems
yea you can fit 33s. But watch out for fender clearance when u turn. i put the 4 inch superlift on and a 3 inch body lift and still had to trim some fender. But i think my problem was becasue of the backspacing on my wheel. (3.625) also with only the 4 inch lift...u wont have much flex.
its relavent to the rims you have. 15x8's usually will clear..the 15x10's(mine) wot clear with out some trimming.
yeah, i just put on 3"BL, AAL, shackles, and a TT with 33's on 15x10's, had to trim quite a bit cuz of the weird backspacing on MT's.
my 33s rubbed a lot (ssr's with 15x8 wheels) with 4" lift and 3" body
each vehicle is different
my 32's with a 2" lift clear fine after some cutting....
I got 4" superlift and 32x 11.50 on 15x 8 rim and I only had to do minor trimming... Pics in sig!
I cleared my 32x11.50 on 3" BL...no cutting
I have the TT/warrior set up and clear 32s with very minor trimming( inner plastic in the front)
Tim
hey man i got a 96 manual explorer and i put some 3 inch leaf spring shackels monroe coil over shocks in the back and heavy duty truck shocks in the front and cranked up my torsion bars 3 inches, basically where my cv's will wear premature but not explode, i wanna put some 31 11.50 super swamper ltb's on it but i need to know if it will fit without rubbing i got 15x8 steel rock crawler rims. if u know man id appreciate it if not thats fine
how in the world am i supposed to lift this car and i couldnt figure out where to post this
<a href="http://photobucket.com/" target="_blank"><img src="http://i129.photobucket.com/albums/p214/bmXplorer/front.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>
