i have a 94 ranger with the 4.0 today it decided to start pinging under a load doesnt do it at itle or with cluch in only when under a load and i dnt get it.
is it pinging or more of a ticking sound? if it's ticking, then its most likely just worn-out lifters. which is annoying, albeit harmless to your truck.
Pinging is very characteristic of the 4.0. I ran premium fuel in mine.
When they get a bit of age and some carbon deposits, they start to have too high a combustion chamber temp. and pinging comes with the territory. Also, have you changed spark plugs and wires? Retain stock Motocraft double platinum for best performance.
I second the loose lower intake bolts...New gaskets and my problems are now gone!
Use the search thread here...LOTS of tips on things to look into and try. You'll be amazed at how simple the problem can be to fix. But sometimes though, you do have an issue that needs to be resolved. Try the simple, the cheap and the easy before throwing money, time and patience at it.
