pitbulldell
- September 10, 2005
- Orlando,Fl
- 95 XLT
I have a 95 4.0 ex . with 235,000 miles on it that is/was pinging under a load when I found this site.I did all the fixes that I found on here and it runs better but it still pings. I use 89 octane gas.
Last week end while pulling a medium size trailer on the interstate going 60 mph once i started up a hill and I would mash on the gas to mantain speed the trans. would down shift and as the rpm's start to climb the engine would start to vibrate you could feel a lose of power then u would hear the valves rattle.
Coming back without the trailer I did a test.I would get up to 85 mph on a flat surface it was fine, then on hill it would do the same thing.You would feel the vibration then the truck would start to slow down and once you mash on the gas to try and pick up speed you would hear the valves rattling. Anything over 85 it would do it even on a flat surface.
I think it is in ralation to rpm's because I notice anything you do aproaching 3,000 rpm will cause this problem.If you turn off overdrive and drive down the road and stomp on it ,it will pull hard in the lower gears, till 3,000 in the higher gears then the vibration starts and valve rattle will follow.
If you put it in park or neutral you can rev it to the moon with no problems at all.it idles smooth and there is no check engine light on.
Here is a list of all the things I have replace in the last 8 months.
IAC
EGR CONTROL MODULE
THROTTLE POSITION SENSOR
MAF SENSOR
PLUGS
WIRES
CRANK POSITION SENSOR
LOWER INTAKE GASKET
IGNITION MODULE
FUEL FILTER
FUEL PUMP
IAC
EGR CONTROL MODULE
MAF SENSOR
PLUGS
WIRES
LOWER INTAKE GASKET
IGNITION MODULE
FUEL FILTER
FUEL PUMP
