Capri302
- June 25, 2006
- SKJETTEN
- 4.0 4x4 1997 Explorer
Hello guys.
I'm havin' a hard time trying to do some repairs on my 1996 4.0 OHV 4x4 Ex. It's been running 250 000 km now and starting getting rusty & a little leaky...
I got some seals last year and I tried to do the front pinion first. No luck loosing the pinion nut. Today I tried once more....
With car on stands, front wheels locked in place I didn't only use all my bodyweight but also heated the nut and tried to undo it by using the jack on the shaft of the wrench.
Shaft is about 1 foot long. The end of the shaft were moved up by the jack about 1- 1,5 feet while you could hear some squealing nices coming from differential and front axles..... But the nut did not move at all. Any suggestions?
Then I had a look at a front engine oil leak. I thought it was the timing cover seal. apparently not; the area around the seal was all dry. Previously I thought it was the oil pressure sender take- off so I tightened it up. It's all dry as well.
Any suggestions on what's leaking? Could it be the steering pump???
Last problem is related to the transaxle. Last winter the Auto/ 4x4 selector seemed to be malfunctioning. It wouldn't go from auto to 4x4. I sthis related to a solenoid?
I looked it up in the Chilton manual, but coudn't find anything.
Thanks for all kinds of help & suggestions...
RS
RS
