Please help! 4.0 sohc soaking plugs in oil? | Ford Explorer Forums
Smitty06
What's up guys I'm a car dealer and recently bought a 06eddie Bauer ford explorer 2wd 4.0 at repo auction. It starts and runs but runs like shi* and smokes like hell! I pulled the plugs and they are soaked in oil! I started checking out motor and the heads look brand spanking new. I mean theyre shiny like they are brandnew. So obviously somebody just did a head job. I'm thinking they got the head gaskets mixed up and it's just dumping oil in? I took out the plugs and turned it over and it just constantly spits oil out the plug holes? Any help will be greatly appreciated!
Usually radiator goes bad and the engine overheats. The heads warp and the piston rings goes bad and they use a ton of oil. If you take it apart the pistons, rings and bores will be worn heaily, seen about 5-6 over the years at the dealership.
