2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
Not much left
You have good compression, you have swapped injectors, and you only have a problem with one cylinder. That leaves either no spark or no injector pulse. I suggest that you replace/swap the spark plug and the spark plug wire. If that doesn't help then I would buy a noid light and check the pulse to the injector.
If the one of the ignition coils were bad two cylinders would be impacted. It is unlikely that the PCM would go bad on just one cylinder.
