Angelite32
- April 1, 2015
- Chattanooga TN
- 2002 ford explorer
I need some major help! My poor 2002 Explorer 4.0 has been down for months and Im still making payments on it
and having to get dropped off at works up to 6 hrs before I have to be there
anyways here we go this is what has been done and what has happened afterwards
So keep in mind this poor this was rode hard and put up wet. We knew this but had no idea what we was getting into. And we are very low on funds....
So was driving on interstate when suddenly it stopped pulling even with foot all the way to the floor. Made it to a gas station and got it pulled home. At this time my husband (has a 2001 Ford Ranger (has had many fords he has fixed on his own) changed all spark plugs and wires, at this point it sounded like it was missing when running so changed the coil pack. Still sounded like missing. Would sound better somewhat when Mass Air was unplugged so replaced that. Checked catalatic converters to find they had been hollowed out. (bad weld job, pretty loud) At this point we had no idea what was going on so got it hauled to a mechanic. Not much can be said about that one they said they fixed a injector (this was after them having it over 2 months) and that was looking for a valve that was making it run ritch. 3 days later they say its jumped time but wouldn't deleiver back home or release it until we threatned to call the law...
Finally get it home, it runs a little better. Will know pull and drive. Still Sounds HORRIBLE. Drove it to the mechanic in town (never died or anything) he called us 2 days later saying there was a spark plug crossthreaded (used a helix to fix) and replaced the coil pack again 9said 2 of them wasn't firing. They advised to replace the serpentine belt (was frayed) and the 02 sensors. Was better driving away got worse as drove home (maybe 2 miles) but was drivable. Husband changed the belt. Sounds horrible again, threating to die drops to 50 rpms. if try to drive it goes in and out from pulling.
Tested downstream sensors after changed them ang only getting around .20 on meter. Sounded a little better. Checked the upward ones and they would get up to around .800 (hubby things propane flame thingie is not hot enough) then drop really fast so he put back in. Now when starts up is very very loud under hood. Now there is a loud knocking noise in engine compartment that will come and go. and still does the drop down to where car is struggling to stay on. Can definetly smell bad gas mixture around car when running.
HELP! Pretty please! This is suppose to be my car, I haven't had one to myself in over 3 yrs, I only got to drive it about 2 months before it went crazy and I miss it! Sorry about all the info but hopefully you smart people on here can help us.
2002 Ford Explorer 4.0 4x4
