Ihve4x4
- March 15, 2011
- Silver Spring MD
- 1998 Limited
I need some help I have a 98 limited 5.0 AWD. I threw a rod and I'm replacing the motor. I decided to put a few upgrades well im in there. The block has forged internals, ARP pick up and oil pump, HS Roller rockers, Ford Racing lifters push rods timing chain and gasket set. Valve springs and seal will be replaced to. I hope I did not miss any thing. Now to the problem I'm not sure how to set the (CPS) camshaft Position sensor. Everything Ive read tells you not to move the crank when you change the cam but that's not a option. All the info I can find is how to change the cam sensor with a tool not how to redo everything. Any help would be great and if there is a sticky for this please point me to it Thanks.
