mountaineerbeast
- May 31, 2011
- Socorro, NM
- 97 Mountaineer
I have a 97 Mercury Mountaineer AWD 176xxx miles.
I have noticed that the steering keeps getting heavier over time. It's really mostly the heaviest at low speeds, like when parking or backing out of a parking spot.
I think it may be the mid-steering shaft because i notice one of the covers was torn.
However, something else to note is that when i turn the wheel the engine revs go up a little bit(that should be normal) and i hear sort of a groaning noise coming from the power steering pump (i've heard that's an indicator of a bad power steering pump).
I've also heard that steering difficulty can come sometimes come from a binding AWD transfer case
. Or it may even be the fact that my frond drive shaft has been getting worse and worse (i already know i need to fix it).
Lastly, is there a chance that my steering could lock up if the mid-steering column gets worse?
I would greatly appreciate it if anybody that has fixed this problem before could help me figure out what it is.
thank you
thank you
