Ploy. sway bar link bushings | Ford Explorer Forums
RON COX
Las Vegas, NV
'91 X, 4 dr. & 03 Ranger
Poly. sway bar link bushings
Does anyone know who makes them for the 91 Explorer and what the part # is? The only ones I can find are a two piece design which won't work. The bushing I pulled out is a one piece that is shaped like an hourglass and no one has them.
From what I have seen, that is the only way they come. Those 2 piece kind are what I am using, and they work better than stock. For as stiff as they are, there would be little or no way that you could push an hour glass shaped poly bushing into your existing sway bar eyelets (sp?):rolleyes:
Oh yeah, you did ask for a manufacturer didn't you? I got mine through Energy Suspension, they are pretty popular.
I've asked around at a couple of off-road shops here and everyone pulls up the same 2 piece design. I know someone has to make them! The kicker is, the link itself also has a hourglass shape too, so a split design doesn't seem right. I have some leaf spring poly bushings from my jeep that I think I can modify to work.
