97greenmonster
- October 9, 2006
- Omaha, NE
- '97 Ford Explorer XLT 5.0
On the 4.0 SOHC motors, the boots dont like to come off that easy, and the passanger side bank is a PITA to get to, so, a good way to get them off is a.........knife, yes, knife. if you get the wheel well cover off and get to the plugs, run a knife along the boot until you can fold it off the plug, after that, take some needle nose pliers and pull the metal thing off the plug and use your plug socket and go from there. now remember, use this method if you plan on replacing the wires as well. Once i did this, took about 10 min a plug!! Just thought id share this little tip with you all!!
Clay
Clay
