60bird
- May 28, 2015
- vancouver wa
- 1999 explorer 4x4
Hi. Just changed the spark plug wires in my 1999 explorer, 4.0 OHV V6. Came out about an hour later and heard a radio playing. Turns out it was coming from my explorer. No key in the ignition or anything, just playing by itself. I turned it off and the clock is still on. I did not disconnect the battery while I changed the wires. Does anyone have an idea what is causing this? The clock should not be on unless the ignition switch is turned on. Also, will just leaving the clock on drain the battery overnight or just not worry about that.
