Possible transmission issue or electrical??? 6r60 | Ford Explorer Forums
07ironmanv8
Jordan, MN
2007 Explorer
Hey guys! Im having a brain melting issue! So! Here is the chain of events and symptoms.
Had the typical trans shutter issue at 110k. Got it flushed and new mercon sp added. Everything is good.
Now at 116k...
Codes:
U0101- lost communication with trans control module
U1900- lost communication with abs, instrament, and 4x4 modules
(Forgot code number) heat catalyst bank 1 below threshold
CAN NETWORK fault
Dash lights on- Wrench, ABS, trac cont.
Symptoms:
Start truck- no warning lights, no issues, runs n acts perfect.
Reverse-typically fine. Sometimes will get jerkey and "limp mode"
Drive- slow accelerations truck will typically get moving and hit the gears just perfect. Fast accelerations, truck will speed up accordingly, then downshift hard and cause a jerking motion like the trans is locking up then losing its place and limp modes for half a second. Rpms will climb and speedo will drop. Once it skips around a few times it will find the right spot and will take off accordingly. However it doesnt seem to be a constant occurance. Sometimes it will take off and run like a bat out of hell. Other times it will skip all around and engauge/disengauge the trans back and forth.
What i have checked/done-
-Abs tone rings- they are the upgraded rings that are thicker.
-I have unpluged each abs speed sensor individually then test drove and nothing changed.
-Unplugged the abs module, nothing changed.
-unplugged the 4x4 module, nothing changed.
-Checked voltage at tps. Looks normal.
-had alternator and battery tested on the truck. Tested good.
-trans fluid is full and clean.
-the transfer case is full and clean
-diffs are full and clean.
-no broken wires that i have found.
-had snap-on scanner on it. All vss rear even and equally.
Other things noticed-
-Speedo will drop when i hit the throttle and it will only drop when the trans acts up.
-holding the break and accellerating seems to help the jerking issue only at times.
-the issue will only happen upon acceleration. Heavy or light.
-the issue is irratic and not consistant.
-all plugs to everything are clean and connect properly....
Bottom line... I understand how everything communicates and i understand more than the basics. But this one here blows my fn mind. Ford charged me 115$ just to tell me the codes and wanted 600$ for full diagnostic. I dont think the answer can be that dam complicated. I feel im missing something... But what!? Has anyone had anything like this??? Iv serched every possible explorer site and they all lead to tone rings and one to battery failure. It is neither. HELP!!!!
07 4.6l 6r60 ironman 4wd
I see you had the alt checked but what is your running voltage with all accessories on? I have seen a 2005 F150 throw crazy codes just for a hair low voltage. Customer of mine had been chasing it for a good 6-8 months before replacing the alt with an OEM Ford one and fixed the issue. That whole 6-8 months he drove it daily but the alt never "failed"
The battery holds 12v on its own. If i remember properly the alternator puts out 13.6v. So i can only imagine that should be within spec... I really do not want to start throwing parts at it left n right... The truck only acts up as you accelerate...
6r60 code U0101 Lost Comm to TCM
Ironman: How did you solve problem? I have same problem, transmission jerking in/out of neutral under acceleration. I can set park brake, put in D or R, get out of vehicle, and it will bang in and out of gear, no one in the truck, engine idling. The code, whenever is set, is " lost communications with TCM" After five transmission shop visits, I have now done the following with no improvement: Newly rebuilt transmission, new Machtronics valve solenoid assembly, new TCM, new Ford flash programming, new plugs, new coils, cleaned all wiring connectors, changed fluid more than once. All of this and the Code U0101 continues, lost comm with TCM. What else is left to do?
Scope data lines at p.c.m when your vehicle displays interment failure you will see a sporadic waveform showing loss of communication from p.c.m hence (uo101) order your p.c.m perform initialization and please burn some rubber will ya
Sorry to renew such an old post… chasing down the same issue with mine. Did you ever get yours figured out?
